Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
plus-sk
Apr 04, 2018Apprentice
Hi Glocknerblick, the only theoretical way to do that is described here: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/What-is-the-AT-entercnd-password/m-p/1427204
But it is not possible since Netgear blocks the use of extended AT commands.
