Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
AoC
Apr 08, 2018Guide
Here's a picture of Huawei B525's network band selection dropdown menu. Something similar would be good to have on the Netgear too. At this moment band locking could be done with AT commands, but that AT command is protected by a password which is still unknown. I believe Netgear fears that people end up to brick their devices with "too" low-level AT commands and therefore they won't reveal the password.
Band selection menu on Huawei B525
Mapcoo
Apr 09, 2018Guide
hello,
this function is very important to force a frequency precis, is there a place in the configuration where we can see when the modem agrees the frequencies to see if it is mimo 2 * 2 or 4 * 4 of the 64 or 265 qam? as well as the rsrp corresponding to each carrier and if they come from a different enodeb
regards,
