Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
Mapcoo
Apr 09, 2018Guide
hello,
this function is very important to force a frequency precis, is there a place in the configuration where we can see when the modem agrees the frequencies to see if it is mimo 2 * 2 or 4 * 4 of the 64 or 265 qam? as well as the rsrp corresponding to each carrier and if they come from a different enodeb
regards,
Mapcoo
Apr 11, 2018Guide
hello
it's possible to show Band Carrier agregation CA like B3+B7+B20 for example
with each Cell ID and RSRP
- MapcooApr 11, 2018Guide
is it possible to allow the selection of text with the mouse to make a copy paste on the field cellid?
regards
- JasonNApr 12, 2018NETGEAR Employee Retired
Hi Everyone,
As of now, Selecting a band for the M1 is not possible yet. The feature has been forwarded to my internal team and they are reviewing for consideration. :]
- Jason N
- MapcooApr 12, 2018Guide
Hi,
thanks for the confirmation
Do you have an idea if it's possible to make an option to force external antenna on the ts9 ports like huawei?
regards,
