Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
Mapcoo
Apr 11, 2018Guide
hello
it's possible to show Band Carrier agregation CA like B3+B7+B20 for example
with each Cell ID and RSRP
Mapcoo
Apr 11, 2018Guide
is it possible to allow the selection of text with the mouse to make a copy paste on the field cellid?
regards
- JasonNApr 12, 2018NETGEAR Employee Retired
Hi Everyone,
As of now, Selecting a band for the M1 is not possible yet. The feature has been forwarded to my internal team and they are reviewing for consideration. :]
- Jason N
- MapcooApr 12, 2018Guide
Hi,
thanks for the confirmation
Do you have an idea if it's possible to make an option to force external antenna on the ts9 ports like huawei?
regards,
or for the moment it's possible to detailed AT commands on this model to do it manualy ?
regards,
- eggYsanJul 17, 2018InitiateI feel ripped off I paid a lot of money for this mobile hotspot for it to crash every movie everything I stream every download every time because it keeps jumping to band 30 which gets one bar And no data! Fix it!
- carleast01Jul 28, 2018Tutor
It's crazy that they don't allow you to choose bands. Where are we with this request. What's really annoying is that this thing is advertised as the fastest thing known to man yet it only achieves 25% of the speed that my phone does! If I reset it then it will sometimes get the same as my phone but it's only a matter of time before it drops back. My guess is that it's to do with the band. I'm stuck in B3.
- darkarbiterSep 18, 2018Tutor
Hello~Jason
after i upgraded my Nighthawk M1 to the lastest firmware
my LTE band only use B3 only, even i changed 3 different iSP sim card and changed position for test
Use of B3 only maked my net speed became very very slow
it seems that CA function is totally malfunction
can you help us solve this condition?
i am sure that My Nighthawk M1 worked pretty excellent before update
there was other person had the same problem also
thank u very much
or u can provide old version firmware?
thanks a lot
I am from Taiwan
- peeedrooSep 24, 2018Aspirant
Hi all
Sometimes my M1 stays stucked with the B20 band (the worst were i live)
I use this tweak that is working with me
I open the netgear android app, then i go to settings, then Network, and on "network mode" i switch to "manual"
The M1 then starts to check every band/internet provider and i think that it also test the speed of each band
Then i select manually my internet provider and then if i go to "advance info" i can confirm that it normally selects other band, and never the B20 (usually the B3 that in my region is much faster). That´s why i think that in manual mode it also tests the speed
Try this simple tweak just to check if the M1 selects other Band
Hope i helped
peedroo
