Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
JasonN
Apr 12, 2018NETGEAR Employee Retired
Hi Everyone,
As of now, Selecting a band for the M1 is not possible yet. The feature has been forwarded to my internal team and they are reviewing for consideration. :]
- Jason N
Mapcoo
Apr 12, 2018Guide
Hi,
thanks for the confirmation
Do you have an idea if it's possible to make an option to force external antenna on the ts9 ports like huawei?
regards,
- MapcooApr 12, 2018Guide
or for the moment it's possible to detailed AT commands on this model to do it manualy ?
regards,
- JasonNApr 17, 2018NETGEAR Employee Retired
Hi Mapcoo,
I will forward that to my internal team with your idea and have them review it for consideration. :]
- Jason N
- Ni_co_lasMay 21, 2018AspirantHi, Does it mean that when plugging external antenna(s), there might be no "direct visible effect" since the router select itself the "best" (or not) antenna in reception (internal or external)? Am I correct?
- MapcooMay 21, 2018Guide
would you have good news to announce us for a likely future firmware with these improvements? it's been over a month since you answered me and since radio silence, can I keep hope? - JasonNMay 21, 2018NETGEAR Employee Retired
Hi Ni_co_las,
This will improve on getting the best band connection that is available with its distance compatibility.
- Jason N
Hi Mapcoo,
Thank you for checking in. Like I said in the earlier post, I have forward the idea to my internal team for consideration. It is up to them if they are going to move forward with the idea. If they decide to move forward then it will be release to the public. :]
- Jason N
