Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
Mapcoo
Apr 12, 2018Guide
Hi,
thanks for the confirmation
Do you have an idea if it's possible to make an option to force external antenna on the ts9 ports like huawei?
regards,
Mapcoo
Apr 12, 2018Guide
or for the moment it's possible to detailed AT commands on this model to do it manualy ?
regards,
- JasonNApr 17, 2018NETGEAR Employee Retired
Hi Mapcoo,
I will forward that to my internal team with your idea and have them review it for consideration. :]
- Jason N
- MapcooMay 21, 2018Guide
would you have good news to announce us for a likely future firmware with these improvements? it's been over a month since you answered me and since radio silence, can I keep hope? - JasonNMay 21, 2018NETGEAR Employee Retired
Hi Ni_co_las,
This will improve on getting the best band connection that is available with its distance compatibility.
- Jason N
