Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
Mapcoo
Apr 12, 2018Guide
or for the moment it's possible to detailed AT commands on this model to do it manualy ?
regards,
JasonN
Apr 17, 2018NETGEAR Employee Retired
Hi Mapcoo,
I will forward that to my internal team with your idea and have them review it for consideration. :]
- Jason N
- MapcooMay 21, 2018Guide
would you have good news to announce us for a likely future firmware with these improvements? it's been over a month since you answered me and since radio silence, can I keep hope? - JasonNMay 21, 2018NETGEAR Employee Retired
Hi Ni_co_las,
This will improve on getting the best band connection that is available with its distance compatibility.
- Jason N
