Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
Mapcoo
Apr 12, 2018Guide
Hi,
thanks for the confirmation
Do you have an idea if it's possible to make an option to force external antenna on the ts9 ports like huawei?
regards,
Ni_co_las
May 21, 2018Aspirant
Hi,
Does it mean that when plugging external antenna(s), there might be no "direct visible effect" since the router select itself the "best" (or not) antenna in reception (internal or external)?
Am I correct?
- JasonNMay 21, 2018NETGEAR Employee Retired
Hi Mapcoo,
Thank you for checking in. Like I said in the earlier post, I have forward the idea to my internal team for consideration. It is up to them if they are going to move forward with the idea. If they decide to move forward then it will be release to the public. :]
- Jason N
