Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
electroMechanic
Sep 16, 2018Star
There won't be any such update. If they do update it they won't provide band selection.
I bought an LB2120, and it is completely useless without band selection, because it jumps to band 20 all the time, randomly, where I get extremely poor download speeds. I informed netgear of this problem using their 90 day complimentary technical support and they didn't even reply, even though I was only asking about this as a suggestion.
Netgear have very poor customer support, and my advice to you is send it back now while you can still receive a refund. I was not so lucky, and the LB2120 is sitting in its box collecting dust (cost me €150).
krzysik
Sep 16, 2018Tutor
Thank you for your answer. In Poland, I have 14 days from the date of purchase. I bought a router from an authorized distributor. I will write to the website with Poland if they do not answer - I will give the router; (
