Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
SirCosmin
Nov 15, 2019Guide
MR1100EUS Firmware Version 12.06.08.00 is available for Europe version.
GetItSet
Jan 28, 2020Aspirant
Sometime in late 2019, an outfit on E-Bay started selling refurbished AT&T (USA) MR1100-2A1NAS Band 14 hotspots – and people bought hundreds of them. I finally bought one. I had hesitated to buy an MR1100 before because of problems other people had when trying to select frequency bands or trying to use the Ethernet connection. I tried it out and it just simply worked – very well. Within hours after I set it up, it notified me that a firmware update was pending. I postponed it but it didn’t do any good – it installed itself anyway the next time I rebooted it. The firmware version now is NTG9X50C_12.05.05.12 (dated 2019/11/26), and it is working fine. The previous firmware on it was dated in the summer of 2018 I believe. I am able to Telnet into it via USB on port 5510 and it allows me to add frequency bands without asking for a password at all (this was after the firmware update – I didn’t try Telnet before the firmware update). Thanks to Olkitu for the Telnet information! I did mess it up the first time I tried it by overwriting the existing setting for “LTE ALL,” but hitting the factory reset button (near the battery) removed that mistake and I was able to try again.
Using the AT!GSTATUS? command on Telnet, it tells me that the MR1100 is doing CA, using Band 30 as primary, and Bands 12 and 2 as secondary bands. With this combination, it is giving me speeds of 50 – 150 Mbit/sec download, and usually 4 - 10 Mbit/sec upload. Typical download speed in the evenings is about 70. If I need to upload Gigabytes of information, I can force it to select Band 14 only. That improves the upload speed to about 20 or so, but the download speed is “only” about 30. Most of the time I just leave it set to LTE ALL so it can do carrier aggregation. For some reason it won’t include Band 14 in the CA though. I’m guessing it’s because that band is shared with first responders, so including it in CA wouldn’t be appropriate. Still, by itself Band 14 does pretty well. I would expect Band 4 or Band 66 to be involved in the mix, but my tower doesn’t support either of those bands (yet).
I connected the Ethernet port to the WAN port of my home router and it just simply worked without hassle. The only change I made was to disable ETHERNET STANDBY (so that it was always working). Other than that, I didn’t need to enable IP PASSTHROUGH or disable the MR1100 as DHCP server. I did try to disable its DHCP server function once to try something different, but that was a bad idea. After that I couldn’t get into its menu to correct that mistake, even if I connected up via USB. A factory reset and restoring my backup configuration file took care of it. I had to Telnet in again to recreate all the frequency band menu selections because a factory reset wipes those out.
