nokiahelp's avatar
Apr 23, 2019
Nighthawk M1 - SIM card not compatible ?
Hello! I've recently purchased a Telstra Nighthawk M1 but it seems not to be compatible with “new” SIM cards (at least in France). My carrier is Free Mobile and my 8 years old SIM card is detected ...
  • nokiahelp's avatar
    nokiahelp
    May 11, 2019
    Blanca_O I did other test with the 3 last SIM cards : as they are 4FF, I tested with an adapter* from 4FF to 3FF and they works, so my new 3FF SIM card is the problem. A solution is to purchase a 4FF Free Mobile SIM card + use an adapter.
    Thanks for your help, problem solved ! :smileyhappy:
    *Yes I hadn't tested with an adapter, so obvious and stupid ^^
