nokiahelp
Apr 23, 2019Tutor
Nighthawk M1 - SIM card not compatible ?
Hello!
I've recently purchased a Telstra Nighthawk M1 but it seems not to be compatible with “new” SIM cards (at least in France). My carrier is Free Mobile and my 8 years old SIM card is detected ...
- May 11, 2019
Blanca_O I did other test with the 3 last SIM cards : as they are 4FF, I tested with an adapter* from 4FF to 3FF and they works, so my new 3FF SIM card is the problem. A solution is to purchase a 4FF Free Mobile SIM card + use an adapter.
Thanks for your help, problem solved ! :smileyhappy:
*Yes I hadn't tested with an adapter, so obvious and stupid ^^
Blanca_O
May 01, 2019NETGEAR Employee Retired
Hi nokiahelp
Please check your inbox.
Blanca
Community Team
Blanca_O
Hi nokiahelp,
Blanca
Community Team
- nokiahelpMay 11, 2019Tutor
