Tricias01
Mar 08, 2019Follower
Nighthawk M1 - Telstra-Aust.
OK So I'm old an may not be the brightest star in the computer game, but I'm angry!
I'm in Australia and use Telstra because of my location. So mobile app nor the http://m.home will take me to m...
Blanca_O
Mar 13, 2019NETGEAR Employee Retired
Hi Tricias01
Welcome to NETGEAR Community!
The default admin password is "admin". If it is not accepting the default password then please reset the unit. Here's the reference link
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf?cid=wmt_netgear_organic [page 72]
Blanca
Community Team
Blanca_O
Mar 24, 2019NETGEAR Employee Retired
Hi PiD_Media
Did you reset the router? If not, please perform a factory reset and try again.
Have you tried using different browser?
Blanca
Community Team
- PiD_MediaMar 29, 2019Tutor
Why would I reset the Router? The problem is the same at every login, regardless of whether the M1 has just been switched on, or has been running for hours.
As I said, the solution is to hit enter at the end of typing in the password, at which point the Sign In button becomes live and can be clicked.
