kubouch
Nov 26, 2019Follower
Nighthawk M1 - use as WiFi router
Due to the changes in our housing, we can get access to a cable Internet instead of relying on mobile 4G connection for which we have used Netgear Nighthawk M1. Is it possible to use the same device as a WiFi router - receiving connection from the Ethernet port and broadcasting it as a WiFi? Not its intended use case but would be good to avoid buying another device.
Thanks,
Jakub
1 Reply
- tsoetantoAspirant
Yes, connect internet source to M1 LAN ethernet port and enable M1 ethernet offload to broadcast Wi-Fi.
