SuzyS0000
Nov 14, 2023Aspirant
Nighthawk M1 - wifi keeps dropping out
I have had my Nighthawk M1 for a year and the performance has never been great, but I have persevered. The kids constantly complain about the wifi, but recently it has got a lot worse. I wonder if th...
Nov 14, 2023Guru - Experienced User
got an old router sitting around?
Put the M1 in passthrough and connect the router to it. Let the route manage wifi and the M1 the data connection
- SuzyS0000Nov 14, 2023Aspirant
Thank you for the suggestion. I do have a Devolo "Magic" wifi mesh which I had been using. I turn the wifi off at the Nighthawk router and go through the Devolo's but it still keeps dropping out.
- plemansNov 15, 2023Guru - Experienced User
Is the Devolo hardwired into the M1 or wireless? If its wireless, hardwire it in.
- SuzyS0000Nov 15, 2023Aspirant
Yes there is a CAT5 cable going from the Nighthawk to the devolo
- michaelkenwardNov 15, 2023Guru - Experienced User
That is not the same as "passthrough" as recommended by plemans.
You need to disable the router bit of whichever M1 device this is.
That or put the secondary router into access point mode.
- SuzyS0000Nov 17, 2023Aspirant
Thank you, I have had a look at the settings and will try that and set "passthrough mode" on
There is also another setting "use router as DHCP server". Should that be on or off?
