nhantenna
Jan 22, 2019Apprentice
Nighthawk M1 + 2 external antennas
I have a Nighthawk M1 with 1 external antenna. Anyone out there have 2 external antennas? If yes, can you share speedtest results between 1 and 2 external antennas? Is it double? About the same?
nhantenna
thanks adzza
a primary way to get speed out of this Netgear 5G evolution hotspot is multiple CA. When I see your speeds double when you add the second external antenna i suspect this is 2 CA. That said, if CA is NOT supported by your local cell tower, i would not expect adding a second antenna to do much speed-wise. anyone else have thoughts on this?
nhantenna
adzza i noticed you state "One antenna (patch)". ie not yagi.
another data point that would be interesting would be one yagi.
- adzzaJan 22, 2019Initiate
I did tst with single Yagi too actually.
Single Yagi: 75/20
I used high quality Yagis, not cheap eBay crap. CA is 700/1800
