nhantenna
Jan 23, 2019Apprentice
Nighthawk M1 + 2 external antennas
I have a Nighthawk M1 with 1 external antenna. Anyone out there have 2 external antennas? If yes, can you share speedtest results between 1 and 2 external antennas? Is it double? About the same?
TeeJay74
Jan 23, 2019Virtuoso
If you have to use external antennas then it is wise to use two. Technically that is not as simple. It depends on on how many bands you have available and how many streams. With 2x2 Mimo it means that one band has two streams. Depending on current air radio condition each stream has CQI which affect stream modulation which directly affects speed. If you have only one band, two streams, both streams are not necessarily in the same modulation.
If you do experiment with one antenna or two, please make sure you have same carrier aggregation combo active when you compare results.
nhantenna
TeeJay74 "please make sure you have same carrier aggregation combo active when you compare results"
can we see the CA details on the nighthawk lcd panel? nighthawk web page? other?
- TeeJay74Jan 23, 2019Virtuoso
No, not able to see that on LCD or webgui. Need to use AT!GSTATUS? command output.
