nhantenna
Jan 22, 2019Apprentice
Nighthawk M1 + 2 external antennas
I have a Nighthawk M1 with 1 external antenna. Anyone out there have 2 external antennas? If yes, can you share speedtest results between 1 and 2 external antennas? Is it double? About the same?
nhantenna
Jan 23, 2019Apprentice
TeeJay74 I live in a rural location. Cell tower to the north. Cell tower to the south. For maximum speed performance do the two external antennas have to be pointed toward the same cell tower? Or can I point one north and one south?
TeeJay74
Jan 23, 2019Virtuoso
Definitely both towards same cell tower.
- nhantennaJan 24, 2019Apprentice
TeeJay74 "Definitely both towards same cell tower."
Since I have one cell tower to the north and one cell tower to the south I was thinking about using two external omni-directional antennas. Then I do not have to point anything. If AT&T wants me on the north cell tower or south cell tower they can move my Nighthawk between towers as they want. Your comment "Definitely both towards same cell tower" has given me pause. If I use two external antennas should I stick with directional yagis or are omni-directional antennas ok too?
- TeeJay74Jan 24, 2019VirtuosoLive testing is needed. Use that tower which gives better performance. So please do testing with directional yagi's with both towers and choose the best. Yagi's narrower beam means it get less interference from other directions and lower interference is a key to better LTE performance. I would use omni's In urban environment where it gets performance benefits utilizing signal reflections.
- JSchnee21Jan 25, 2019Virtuoso
Hi Folks,
A couple questions / comments if you wouldn't mind:
1) Can you provide a url to the Yagis you've purchased that are working so well?
2) Are they mounted at a 45 degree angle / 90 degree versus each other?
3) How did you adapt from the antenna connector to TS-9? How long are your cable runs and what kind of Coax did you use?
Currently, my understanding is that ALL CA is INTRA tower. So, multiple antennas have to point to the same tower or there will be no CA (or very poor CA with a much weaker signal).
Best,
Jonathan
