jestexman
Mar 05, 2018Tutor
Nighthawk M1- Ethernet Port Speed?
Looking for full specs of this router.. Is the ethernet port 300mb or Gb speed? Is the usb port usb2 or usb3?
- Mar 05, 2018
Hi jestexman,
Below are the links to the M1 user manual / the data sheet / and support page:
Please let me know if you need anything else. :]
Data Sheet:
https://www.netgear.com/images/datasheet/mobile/MR1100.pdf
User Manual:
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
Support Page:
https://www.netgear.com/support/product/MR1100.aspx#Troubleshooting_CommonTopics
- Jason N
JasonN
Mar 05, 2018NETGEAR Employee Retired
Hi jestexman,
Data Sheet:
User Manual:
Support Page:
- Jason N
- jestexmanMar 05, 2018Tutor
Thanks..So looks like ethenet is limited to 500mb.. Why have a GB Router that can only do 500mb on the ethernet.. I guess we are lucky it has AC wifi as that can do GB..
