Christian1981's avatar
Jan 30, 2019
Nighthawk M1 / MR1100 Firmware Update (12.05.05) Failure
I tried to update the Firmware from my Nighthawk M1 Router from 12.04.02.00 to 12.05.05.00 and it failed.   I did the following: Downloaded the Firmware 12.05.05 from Netgear's official suppo...
  • ErwinCr's avatar
    ErwinCr
    Feb 19, 2019
    I'm guessing the update is not for the EUS versions.
    When updating the router says the update is not intended for this device.
    I went on the dutch website and there is an update "MR1100-100EUS_23113509_NTG9x50C_12.06.03.00_00_Generic_05.01.secc" and this one works.
    You may wanna change the country of the support site (bottom of the page) your country or a logical country nearby (Belgium>>> Netherlands).
    And indeed, the update from within the router doesnt work.
