Christian1981
Jan 30, 2019Tutor
Nighthawk M1 / MR1100 Firmware Update (12.05.05) Failure
I tried to update the Firmware from my Nighthawk M1 Router from 12.04.02.00 to 12.05.05.00 and it failed.
I did the following:
Downloaded the Firmware 12.05.05 from Netgear's official suppo...
- Feb 19, 2019
I'm guessing the update is not for the EUS versions.
When updating the router says the update is not intended for this device.
I went on the dutch website and there is an update "MR1100-100EUS_23113509_NTG9x50C_12.06.03.00_00_Generic_05.01.secc" and this one works.
You may wanna change the country of the support site (bottom of the page) your country or a logical country nearby (Belgium>>> Netherlands).
And indeed, the update from within the router doesnt work.
Blanca_O
Feb 12, 2019NETGEAR Employee Retired
Welcome to NETGEAR Community!
May I please know the exact model of your MR1100? Where did you purchase it?
Kindly try to log into the M1 Web UI using http://m.home/ and update the firmware.
Blanca
Community Team
Christian1981
Feb 12, 2019Tutor
Hi Blanca_O ,
Web UI is not working with http://m.home/
I need to use http://m1login.net and I already tried to update from there. Result: No Update found.
Exact Model is MR1100-100EUS_04.01.67.00
Best,
Christian
- ErwinCrFeb 19, 2019Aspirant
And indeed, the update from within the router doesnt work.- Christian1981Mar 09, 2019Tutor
Thx ErwinCr. I used your link to download the latest firmware and it worked. - Really confusing: When you switch Netgear support website to German, you are downloading a different firmware version (and Button/Text remains the same).
- W1lliamFeb 26, 2019Virtuoso
FW for this model can be found at http://www.downloads.netgear.com/files/GDC/MR1100-100EUS/MR1100-100EUS_23113509_NTG9x50C_12.06.03.00_00_Generic_05.01.secc.spk
You can then upgrade your M1 via Web GUI->SETTINGS->Administration->Firmware Update->Upload Firmware
- baileyrhood90Mar 01, 2019Tutor
I have several Nighthawk M1's, MR1100-1A1NAS and MR1100-2A1NAS. When I go to administration and then firmware, it does not give me the option to upload firmware. Any idea why or how to make this work? These are the AT&T US versions of the MR1100 and I was able to download the firmware I need for the model from the Netgear site. I just can't upload it. And about 95% of the time I can't get these to update when I do "check for updates" within the hotspot GUI. I set these up for other people all the time because I live in an area where we can't get good internet. I just want to be able to update them all to the latest firmware. I would appreciate any advice. Thanks.
- TeeJay74Mar 02, 2019Virtuoso
I assume the upload button is visible. Upload button works after firmware file is selected by browsing. Then the file version should be suitable for your SKU.
