Christian1981
Jan 30, 2019Tutor
Nighthawk M1 / MR1100 Firmware Update (12.05.05) Failure
I tried to update the Firmware from my Nighthawk M1 Router from 12.04.02.00 to 12.05.05.00 and it failed.
I did the following:
Downloaded the Firmware 12.05.05 from Netgear's official suppo...
- Feb 19, 2019
I'm guessing the update is not for the EUS versions.
When updating the router says the update is not intended for this device.
I went on the dutch website and there is an update "MR1100-100EUS_23113509_NTG9x50C_12.06.03.00_00_Generic_05.01.secc" and this one works.
You may wanna change the country of the support site (bottom of the page) your country or a logical country nearby (Belgium>>> Netherlands).
And indeed, the update from within the router doesnt work.
Christian1981
Feb 12, 2019Tutor
Hi Blanca_O ,
Web UI is not working with http://m.home/
I need to use http://m1login.net and I already tried to update from there. Result: No Update found.
Exact Model is MR1100-100EUS_04.01.67.00
Best,
Christian
ErwinCr
Feb 19, 2019Aspirant
- Christian1981Mar 09, 2019Tutor
Thx ErwinCr. I used your link to download the latest firmware and it worked. - Really confusing: When you switch Netgear support website to German, you are downloading a different firmware version (and Button/Text remains the same).
