AMOB
Jan 19, 2020Aspirant
Nighthawk M1- no wifi visible to connect to
Hi From one day to the next did the wifi network from my Nighthawk MR1100 did not show up anymore on my iPhone SE or my Laptop (Lenovo L480) wifi list. The only thing I did the day before was too pu...
Ksa3344
Jan 25, 2020Apprentice
Have you tried to connect your nighthawk to your laptop via USB or Ethernet ?
and if it works make sure IP Passthrough isn't enabled.
AMOB
Jan 28, 2020Aspirant
I connected to the Laptop via usb cable and it shows the connection and I can go into the setup. However the internet connection is super slow and not the speed it was.
Further I can still not see any wifi network. And I don't know what I can change in the setting to make the wifi work again?
