AMOB
Jan 19, 2020Aspirant
Nighthawk M1- no wifi visible to connect to
Hi From one day to the next did the wifi network from my Nighthawk MR1100 did not show up anymore on my iPhone SE or my Laptop (Lenovo L480) wifi list. The only thing I did the day before was too pu...
JohnPeng
Jan 26, 2020NETGEAR Expert
Please provide the SKU name of your device.
You can connect the device to your laptop using the USB cable shipped with the device. Then you should be able to log in to WebUI to check whther WiFi was turned off.
Thanks
AMOB
Jan 28, 2020Aspirant
SKU: MR1100-100EUS
Model: MR1100-100
SN: 5D6285NF004BD
When I go into m1login.net, I can see that the settings look normal. Wifi is on dual and nothing seems out of place or 'unclicked'.
I reseted it as well through the browser to factory settings and nothing changed afterwards.
- Ksa3344Jan 29, 2020Apprenticetry to head to
settings - setup - wireless
then check if hiding SSID is marked remove the mark and it will work.
Also check
settings - setup - Mobile Router Setup
and make sure the IP Passthrough is off and the turn off wifi when tethering is not marked.
Hope this will solve your problem
