Srennie837
Jan 24, 2018Tutor
Nighthawk m1 4g+ only
Hi, My Nighthawk M1 (EE UK, not US) is currently connecting to a mast with 5 bars of signal on 4g, and gets 10mb/s speeds. There is an other local mast with 3 bars of signal on 4g+, and can get u...
TeeJay74
Jan 24, 2018Virtuoso
You could try with directional antenna. Inter-site CA is not yet possible.
Srennie837
Jan 25, 2018Tutor
Is there anyway to select which band to prefer then? Currently I'm on band 3 but band 7 is faster on the other mast. I'm on setting 02 which is LTE only, but I know in previous Air Cards you can adjust through the AT settings to add more choices.
