Srennie837
Jan 24, 2018Tutor
Nighthawk m1 4g+ only
Hi, My Nighthawk M1 (EE UK, not US) is currently connecting to a mast with 5 bars of signal on 4g, and gets 10mb/s speeds. There is an other local mast with 3 bars of signal on 4g+, and can get u...
TeeJay74
Jan 26, 2018Virtuoso
Band locking can be useful in some situations and Netgear knows this. I see UE band locking features as a tool for handling special situations. MR1100 webgui does not have this kind of feature at the moment. Let's hope that developers add this feature to future firmware release. Automatic band selection does not always bring best actual performance and that is a real problem. Anyone who has done a lot of fieldtesting knows about this.
Srennie837
Jan 26, 2018Tutor
Yeah I wish you were able to do it in the gui. I know you can do it once you have got past the "AT!ENTERCND" menu through telnet port 5510, but without the correct password that is as far as I can get unfortunately.
- Srennie837Feb 02, 2018Tutor
II've managed to get this info out of the modem.
AT!GSTATUS?
!GSTATUS:
Current Time: 16966 Mode: ONLINE
System mode: LTE PS state: Attached
EMM state: Registered Normal Service
RRC state: RRC Connected
IMS reg state: No Srv
PCC:
LTE band: B3
LTE bw: 20 MHz
LTE Rx chan: 1667
RSSI (dBm): -33.0
RSRP (dBm): -59.3
RSRQ (dB): -7.7
RSSNR (dB): 30
Tx Power (dBm): -21.0
LTE Cell ID: 5089538
Physical Cell ID: 349
TAC: 11694
AT!GSTATUS?
!GSTATUS:
Current Time: 17273 Mode: ONLINE
PCC:
LTE band: B3
LTE bw: 20 MHz
LTE Rx chan: 1667
RSSI (dBm): -72.8
RSRP (dBm): -104.3
RSRQ (dB): -8.6
RSSNR (dB): 10
Tx Power (dBm): 22.0
LTE Cell ID: 4470786
Physical Cell ID: 416
TAC: 25086
SCC1:
LTE band: B20
LTE bw: 5 MHz
LTE Rx chan: 6225
RSSI (dBm): -65.8
RSRP (dBm): -88.0
RSRQ (dB): -8.3
Physical Cell ID: 366
I obviously want to connect to the second of the two as it is using 2CA, netgears customer service is appaling though.
The issues I had had trying to get some resemblence of help are;
The chat service - advised to use this on the support page, and they don't support mobile dongles, what they call "air cards"
The telephone "technical" service - reading from a script, and won't help as "they don't have the training" literally what I was told. would'nt pass me onto someone that could. Told me to contact community support.
The e-mail service - Don't read the tickets, told me to contact the ISP if I needed a return/replacement.
Literally the response "As per the serial number of your device, we were able to identify that your unit is not a retail product. This type of unit is engineered / customized based on the needs of an Internet Service Provider and can only be obtained through them. This means that the support including the replacement / return should be handled through the Internet Service Provider which the product was obtained"
EE don't manufacture the devices so why should they support it in this manner?
The company is impossible.
- TeeJay74Feb 02, 2018Virtuoso
Hi,
I think your EE MR1100 is not faulty. That single cell B3 signal strength is so much stronger (RSSI -33) than other B3 so highly likely that is going to be selected as PCC. On the other hand, sim card should have a list of preferred band combinations, with CA or without. That affects band selection too. Signal values are everchanging and device should select "best" service. In real world that selection is not always providing best performance. Some issues belong to the nature of 4G LTE technology which has some weaknesses. In your case I would try to use directional mimo antenna's to get stronger signal from that B3+B20 direction. This should work if both towers are not in same direction.
- Srennie837Feb 02, 2018TutorThanks for your advice, I was really hoping there was a way to do it with software so I wouldn't have to buy a mimo yagi array, I'm too lazy to build one.
Oh well, I never thought there was an issue with my device, I'm so close to the bad mast that I'm worried that even with a highly directional antenna it might still pick up the unwanted mast.
I'll build the antenna over the weekend and give it a go.
