Greynomand
Oct 11, 2017Tutor
Nighthawk M1 and Arlo Support
When will the support be ready for Arlo for the Telstra Nighthawk M1
- Dec 04, 2017
Hi Greynomand,
Should be available mid Q1 2018. Look out for a firmware update around that time.
ArodiD
Addyhash
Nov 25, 2017Apprentice
but that will be a 4G connection, In Austalia ISP's for 4G internet use a private Ip address, so how are you supposed to access the cameras remotely?
I've tried using an E5573 -> MR3420 -> Netgear base station, and was unable to connect to the base station...
If there is a work around i would be very interested.
ArodiD
Dec 04, 2017NETGEAR Expert
Hi Addyhash,
It uses cameras use cloud servers so does not require public IP or manual port forward configurations. For more info please check out this link: https://www.arlo.com/au/default.aspx
ArodiD
