ccsmith51
Mar 18, 2022Aspirant
Nighthawk M1 and AT&T
I have a Nighthawk M1 hotspot and an AT&T unlocked SIM. In my discussion when I say "connect" I mean no internet. At times the M1 will not connect. Other times it connects and runs for hour...
JohnPeng
Mar 19, 2022NETGEAR Expert
If you are using MR1100-100NAS SKU with AT&T SIM, the issue may be due to AT&T blocks the SIM plan to be used on M1.
Thanks
- ccsmith51Mar 19, 2022Aspirant
Thanks, John. It is that SKU. But if they were going to block the plan why would they allow it to work sometimes for hours at a time, and then other times for only a few moments? Why would they turn it on and off?
- JohnPengMar 19, 2022NETGEAR Expert
This depends on how network sets up the rules to check. Some networks checks when the device tries to connect to the network/. Then the data connection will be rejected right way with the cause of Illegal UE. Some network may check periodically on the blocked devices and disconnect the data connection.
Thanks
