Toogy1206
Jan 26, 2018Aspirant
Nighthawk m1 Antennas
 Hey everyone.  I have a quick question that i cant seem to find a clear answer for.  Im new to this.  I have a nighthawk m1 and im using it as my main source of internet at my home.  If I were to att...
Jensmobile
May 14, 2018Aspirant
Hi, there are two antenna slots for you to insert an external antenna to your netgear M1 MR1100 to boost the signal strength when you are at a rural area where the signal strenght is weak.
- MAGADEMay 19, 2018Guide
So, to be clear, the extern antenna connector TS9 is for LTE antenna, NOT FOR WIFI.
If you need wifi range boost, you need to try to select long range wifi signal in web interface or connect a wifi extender device.
The TS9 connector will help you to got a signal boost about range (distance) not boost the SPEED TRANSFERT in my mind.
