mufngruf
Aug 14, 2019Aspirant
nighthawk M1 battery indicator
simple question - I have studied the booklet, searched the website and googled 'til my finger bled.. but I can't find the answer.
My Nighthawk thingy has a circular battery light - at least that's what I think it is.
The left hand side semi-circle is half yellow and half purple... the right hand side is all purple.
The base of the left hand side is a small empty battery icon... the bottom of the right hand side is a pair of opposing arrows....
should be pretty self explanatory, I suppose but I'm goshdarned if I can figger it out..
Anyone help??
thanks
