MFK2020
Jun 21, 2020Aspirant
NIGHTHAWK M1 BOOTLOOP
Hi all, My modem wont start after updating it , since it's on boot loop
MFK2020
Jun 26, 2020Aspirant
Hi ,
Thanks for your answer
Yes I did the resetin different with and without different SIM , Battery , Rest power off and power on .
I did try the FTFP server to install the update without success
I do not have the serial number as I sent it to a friend to have a look on it , I will get back with the number as soon as I have it .
I think it need to be completly flashed , I do not know the way to do it
