Synonomike
Nov 10, 2019Follower
Nighthawk M1 Can’t do manual firmware update
Hello I am trying to do a manual firmware update (currently 10.12.02.01) When I log into the router to do an update there is no option to do this manually (upload from a saved file. This router...
michaelkenward
Nov 11, 2019Guru - Experienced User
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
