firstnetgirl
Apr 04, 2018Aspirant
Nighthawk M1 can operate without battery when plugged into the charger?
Does anyone know if this hotspot can operate without the battery when plugged into the charger?
JasonN
Apr 17, 2018NETGEAR Employee Retired
Hi firstnetgirl,
Can you confirm that you are talking about the Nighthawk M1 (MR1100)?
Please refer to the link below for the information that you need.
You are able to run the M1 without the battery.
Make sure that your AC unit has enough power to power the device.
Please let me know if you have any other questions. :]
- Jason N
- firstnetgirlApr 17, 2018Aspirant
Thank you that is very helpful.
- JasonNApr 17, 2018NETGEAR Employee Retired
Hi firstnetgirl,
I'm glad I could be of help to you. :]
- Jason N
