Piet200
Nov 09, 2022Follower
Nighthawk M1 connect to LAN (ethernet cable)
I am looking for a setup to use the M1 mobile router as a backup of my internet on my lan. Does anyone know if this is possible? It does look like that I can hook it up to my wifi network and ma...
JohnPeng
Nov 13, 2022NETGEAR Expert
Try WiFi OR ETHERNET offloading feature and see whether that is what you need.
Thanks
It does look like that I can hook it up to my wifi network and make it function as a backup in that way. but not when I connect it to my network using the lan port.
I tried the 'IP passthrough' setting, but that doesn't work at all.
Any suggestion is welcome.
