KarmusDK
Apr 19, 2018Apprentice
Nighthawk M1 custom fan
Hi everyone. Just wanted to share a little fun setup I made out of boredom. I found a spare slide switch and a 5V fan in my electronics box and also a 2 AA batteries socket connected in serial. I sol...
JasonN
Apr 19, 2018NETGEAR Employee Retired
Hi KarmusDK,
Thanks for sharing your custom fan for your M1! Please let us know how well that works! :]
- Jason N
KarmusDK
Apr 20, 2018Apprentice
It's not as effective as a bigger sized fan with a higher voltage, so it probably only makes a very little difference, but it was mostly just a creative idea to how the heat problems could be solved. In a realistic setup you would either need to remove the cover lid to enable proper ventilation or replace it with an alternative one with holes, and you could attach the fan to the board with a little piece of double-sided bonding tape in the center area.
- KarmusDKApr 20, 2018Apprentice
You also have to frequently change batteries. Like once every hour, to keep the spin cycle high enough. Make sure you have an alkaline charger, so you don't produce more chemical waste than necessary. A PSU would certainly be a better option, or a solar panel if you're an environmentalist. As long as it's daytime, solar energy can power your fan for many hours while charging a battery to continue the rotations for the rest of your awake time.
This is something like what I was talking about. If you find one of plastic, you could do a cut out to match the shape of the router lid and use a couple of cable ties to fasten it after you have lead the power cable out through one of the lower holes in the grid.
- JasonNApr 20, 2018NETGEAR Employee Retired
Hi KarmusDK,
Yes, understandable. You can put both together for a more effective solution. Like the fan and vented covers on a laptop. :]
- Jason N
Just ordered this fan. It runs on USB power (5V), so it's not very useful in its current form, but I measured the box and it should fit beneath, so I'll see what I can do when I get it, perhaps tweak it a little bit to make it accept a higher input.
