Chuckbear
Jan 24, 2021Follower
Nighthawk M1 data offloading won't hold
When I try and set up data offloading via wfi I can't get the M1 to keep the settings. I enable offloading, click wifi and then Apply. The router restarts but the offloading is not enabled and i nev...
derek42
Mar 29, 2021Aspirant
Have exactly problem on my new M1.
Offloading works fine using ethernet, but when I try WiFi dashboard says Not Connected. I've tried 2.4, 5 and dual and get same results.
