Chuckbear
Jan 24, 2021Follower
Nighthawk M1 data offloading won't hold
When I try and set up data offloading via wfi I can't get the M1 to keep the settings. I enable offloading, click wifi and then Apply. The router restarts but the offloading is not enabled and i nev...
W1lliam
Mar 30, 2021Virtuoso
tried with battery installed data offload over WiFi, it does work (firmware 12.06.x), even reboot M1 without battery, the setting still remained and works
