kcey
Apr 24, 2018Tutor
Nighthawk M1: Device offline after firmware update.
After installing the data usage corrective firmware my unit is dead. Light indication is alternate blue and amber flashes.
Any suggestions?
- Apr 25, 2018
So I took the unit to Telstra. They took the battery and sim card out then replaced both. IT WORKED!!!
YAY!!
JasonN
Apr 24, 2018NETGEAR Employee Retired
Hi kcey,
Have you done a factory reset after your update? Which model M1 is your device? (Telstra / AT&T / etc.)
What firmware version are you at?
Please let me know. :]
- Jason N
kcey
Apr 24, 2018Tutor
Factory reset:- no change.
Not able to use either the app or web as the nighthawk is not on any network (dead).
Firmware used:- MR1100-1TLAUS_23113199_NTG9x50C_10.25.01.01_00_TELSTRA_03.22.secc.spk
The unit continues to blink at me. Blue then amber. Nothing else happening!
