kcey's avatar
kcey
Tutor
Apr 24, 2018
Nighthawk M1: Device offline after firmware update.
After installing the data usage corrective firmware my unit is dead. Light indication is alternate blue and amber flashes. Any suggestions?
  • kcey's avatar
    kcey
    Apr 25, 2018
    So I took the unit to Telstra. They took the battery and sim card out then replaced both. IT WORKED!!!
    YAY!!
