schoollane
Mar 14, 2021Initiate
Nighthawk M1 does not port forward
Hi All, Having problems with my router and port forwarding. the router has been factory reset and default settings are used. port rules have been setup in port forwarding after a reboot google my...
michaelkenward
Mar 15, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
These are specialist kit that doesn't share a lot of controls and features with standard Nighthawk WiFi Routers, hence its own bolt hole.
I will ask the Netgear moderator to move your message.
