schoollane
Mar 14, 2021Initiate
Nighthawk M1 does not port forward
Hi All, Having problems with my router and port forwarding. the router has been factory reset and default settings are used. port rules have been setup in port forwarding after a reboot google my...
antinode
Mar 15, 2021Guru
> after a reboot google my external ip [...]
What's the IP address of the WAN/Internet interface of the MR1100?
Does it match the "92<hidden>" which you're testing?
There's no good reason to hide any of your server's private (LAN) IP
address ("192<hidden>").
For the usual problems with port forwarding, see:
