flixs
Sep 29, 2020Aspirant
Nighthawk M1 doesn't see Arlo Cam
Hi guys, I recently need my Nighthawk connected with 2 Arlo HD cams (not a pro, just a "cheap" probably older Arlo HD) I was able to enable arlo at the Netgear and it should also been connect...
Sep 29, 2020Guru - Experienced User
You don't add the arlo cameras to the M1. You add it to the arlo base station. You'd want to contact arlo support for assistance connecting the cameras tothe base station.
