flixs
Sep 29, 2020Aspirant
Nighthawk M1 doesn't see Arlo Cam
Hi guys, I recently need my Nighthawk connected with 2 Arlo HD cams (not a pro, just a "cheap" probably older Arlo HD) I was able to enable arlo at the Netgear and it should also been connect...
flixs
yea, but with the Arlo app, and this doesn't see the M1 as base nor the cam
Sep 29, 2020Guru - Experienced User
it won't see the M1 as base. You actually need an arlo base with many of their models.
- flixsSep 29, 2020Aspirant
- plemansSep 29, 2020Guru - Experienced User
I believe that was right before/at the time of the arlo/netgear separation. Arlo is now its own company/entity.
There was work at including arlo into the orbi router but it got dropped during the separation.
- flixsSep 30, 2020Aspirant
whaaat, damn!
but the feature in the M1 is still there. And nowhere is an info that you cannot do this anymore :(
