Marcus1981
Oct 21, 2020Tutor
Nighthawk M1 Drops Connections Nightly with my Tplink Router! Help Please
I have my netgear plugged into my tplink Archer c50 router and everynight I have top reset nighthawk because I lose connection! I have wifi off on my nighthawk and use the tplink for wifi! Any sugges...
- Oct 27, 2020
Hi Marcus1981
Welcome to NETGEAR Community!
Kindly access MR1100 settings page and make sure that Ethernet Standby and WiFi Standby settings are set to disabled.
Access UI > Settings > Setup > Mobile Router Setup > Ethernet Standby (disabled or 2 minutes)
Access UI > Settings > Setup > Wireless > change WiFi Standby to Disabled.
Blanca
Community Team
Blanca_O
Oct 27, 2020NETGEAR Employee Retired
Hi Marcus1981
Blanca
Community Team
Para61
Nov 05, 2020Aspirant
I have the same problem and have read something about the battery and the charger causing the router to overheat. I just made the changes you suggested, hence disabled the Ethernet Standby and WiFi Standby settings. We shall see.
