agdodge4x4
Nov 28, 2017Luminary
Nighthawk M1 Drops Internet Overnight....why?!
I'm on week 2 of trying to get this device to work as advertised or expected. I finally have it working as a pure modem.....kinda. I have a TP Link Router that is my main home router. The M1 ha...
agdodge4x4
Dec 01, 2017Luminary
That option is NOT available in mine. It is likely that it is not available in IP Passthrough mode, which is how mine is set up.
ArodiD
Dec 04, 2017NETGEAR Expert
Hi agdodge4x4,
If the ethernet port detects there is nothing plugged in it will switch OFF. You can tap the power button to wake it back up again. By default on power up the ethernet port is active for 2mins. If it detects something plugged in it will remain active, if it does not detect anything plugged in it will switch OFF and require a tap of the power button to wake it up.
Kind Regards,
ArodiD
