DMcCookie's avatar
DMcCookie
Nighthawk M1 Dynamic DNS support
Hello,
Can anyone please confirm whether the Nighthawk M1 router supports Dynamic Dns so it can be used for remote access without a fixed IP?
Thanks in advance
David.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Not supported directly by M1 but you can use dyn DNS service such as http://dyn.com/dns/ which would work fine. Dyn would map the dynamic IP the M1 is getting from ISP to enable remote access.
    DarrenM
    • DMcCookie's avatar
      DMcCookie
      Thanks Darren,
      how would Dyn know the ip unless something at that address was contacting it, such as a computer with their app on it or a router set to contact the Dyn servers?
      In my experience I'd need the router to have a setting so I can tell it to contact dyn with its dyn host ID.
      Thanks again
      David
  • As far as I can tell there is no Dynamic DNS support in any of the menu options which is very disappointing.  If you have port forwarding support you should really have Dynamic DNS support. Hopefully, some new firmware comes out soon with this feature enabled.  If you do not have Dynamic DNS on the router then there is no ability for the device to tell DNS services of a change of IP address as far as I am aware.  Any idea if Dynamic DNS is being added in an upcoming release Netgear support?  If so how far away otherwise I will need to look at purchasing alternative Mobile Broadband units such as Netcomm?
    • DarrenM's avatar
      DarrenM
      Hello JohnMcG007
      No plan at the moment for Dynamic DNS
      DarrenM
      • JohnMcG007's avatar
        JohnMcG007
        Tutor
        Hi Darren,
        Thanks for getting back to me.
        Please, please, please (sorry to sound like I am desperate but I am) is there any way that Dynamic DNS can be reconsidered very soon?.  I am looking for the speed that these network devices provide with the plan to use many hundreds of them over time for business purposes to run remote cameras. The cameras do not have the smarts to do this.
        Thanks
        John
