tdblanchard
Oct 31, 2020Initiate
Nighthawk M1 ethernet port not working
I finally got around to hooking up my M1 at the farm house where we intend on using it yesterday. One issue I was having was connecting an AC1750 router to the ethernet port. I was able to determin...
Legends619
Dec 31, 2020Aspirant
I have had the nighthawk m1 hotspot with the netgear mesh 60 router for almost a year with no problems. Now the ethernet port is not working ive reset everything to factory setting messed with every setting . No luck. I live in the mountains so this is my primary internet. The wifi still works but i need the ethernet connection to my router to get the range to cover my whole house. Help plz
- tdblanchardDec 31, 2020Initiate
I'm not at our farm right now but the resolution that worked for me was in the M1's settings.
Something to do with the USB port settings. it wasnt at all intuitive but it worked. I'll dig for the actual setting in a few
- TL_NTGRJan 04, 2021Apprentice
Log into the MR1100 (M1) web settings and setting the USB Tethering setting to Charge only and set the Ethernet Standby setting to Disabled.
Odd that this was working for a year and now not working. Can you connect a laptop to the Ethernet port on the MR1100 and confirm it's working properly?
- Twitcho8Mar 08, 2021AspirantAnyone figure out this issue? Mine just all of a sudden turned off the ethernet port. It seems like the latest firmware could have done it? I’ve tried resetting to factory settings then changing usb to charge only and disable off. But still acts as if the port is complete dead.
