tdblanchard
Oct 31, 2020Initiate
Nighthawk M1 ethernet port not working
I finally got around to hooking up my M1 at the farm house where we intend on using it yesterday. One issue I was having was connecting an AC1750 router to the ethernet port. I was able to determin...
Lad58
Oct 21, 2021Aspirant
Nighthawk mobile hotspot mr1100 at&t
ethernet not working
have tried everything suggested and net gear just told me to call back next day they didn't know anything
I have only had it for 4 days and need to plug in an extender because it has no range compared to old one. This is second one I have tried. No luck if anyone has a solution it would be greatly appreciated
thank you
TL_NTGR
Oct 21, 2021Apprentice
Check the Nighthawk MR1100 and Extender IP address range. If both use 192.168.1.1 then that's the problem. Change one of them to use a different LAN network. Example, change the Extender to use 192.168.2.1 then connect to the Hotspot.
