tdblanchard
Oct 31, 2020Initiate
Nighthawk M1 ethernet port not working
I finally got around to hooking up my M1 at the farm house where we intend on using it yesterday. One issue I was having was connecting an AC1750 router to the ethernet port. I was able to determin...
TL_NTGR
Dec 16, 2020Apprentice
Hey guys, Two things to check. Log into the hotspots management page (web browser at 192.168.1.1) and in the Mobile Internet check the following settings.
USB - Charge + Tether <- Set this to Charge only as USB will take priority over the Ethernet connection. This will force the tether to Ethernet
Ethernet Standby Timer <- Set this to disable. Ethernet port goes to sleep on no link activity after 2 minutes unless disabled.
Hope this helps!
jimfire23
Mar 14, 2022Aspirant
I have a netgear mr1100 plugged into the wall for power and with the ethernet plugged into the router. working just fine. when i remove the battery the ethernet loss concretion to the router. Do I need to take it back?
