tdblanchard
Nov 01, 2020Initiate
Nighthawk M1 ethernet port not working
I finally got around to hooking up my M1 at the farm house where we intend on using it yesterday. One issue I was having was connecting an AC1750 router to the ethernet port. I was able to determin...
jimfire23
Mar 15, 2022Aspirant
I have a netgear mr1100 plugged into the wall for power and with the ethernet plugged into the router. working just fine. when i remove the battery the ethernet loss concretion to the router. Do I need to take it back?
TL_NTGR
Mar 15, 2022Apprentice
Make sure you are using the supplied charger block as other USB ports might not supply enough power. What SKU of MR1100 is this? Look under the battery on the label?
- Pierrealex32Mar 15, 2022AspirantSo we finally got internet in our area and the mesh 6 is working so it’s definitely the M1 Nighthawk Hotspot.
- jimfire23Mar 15, 2022AspirantYes it is the power cable it came with. I did a factory reset again. That is the only way it seems to be the only way it works
- Pierrealex32Mar 15, 2022AspirantFactory reset wouldn’t even work for mine.
- jimfire23Mar 15, 2022AspirantDid you return it and exchange it and did it make a difference
